Need to Understand Anti-Siphon vs AVB
Todd F
North Carolina
Dear Forum,
I'm trying to understand if the "Anti-Siphon" function built into hose bibs today is effectively just an "Atmospheric Vacuum Breaker"?
Thanks so much,
...Todd
That is pretty much true. However I expect the anti-siphon valve on the hose bib to leak, and the vacuum breaker usually not to leak as readily. ;)
Todd F
North Carolina
I'm probably splitting hairs but...
Plumbing code SPECIFICALLY says you can't have a valve downstream of an "AVB"... but doesn't say "anti-siphon valve".
Just trying to see if I can make the case that AVB is NOT Anti-siphon?
Your thoughts?
Thanks ...Todd
That suggest a distinction: how about saying that an anti-siphon valve is a vacuum breaker that is after the last valve before a spigot intended to connect to a hose? That seems to go along with the way they are labeled when sold, right?
So I am suggesting that by putting a valve between the air admitance device and spigot, you cannot call that an anti-siphon valve servicing a hose spigot.
Clearly the vacuum breaker's job is to avoid a siphoning, but not to a hose. https://terrylove.com/forums/index....-for-softener-filter-on-input-or-output.63102 is a little thread discussing vacuum breakers for softeners. Water heaters not on the bottom floor should have a vacuum breaker.
Smooky
North Carolina
Your thoughts?
Thanks ...Todd
Sec. 70-578. - Definitions
Atmospheric vacuum breaker (AVB) means a device that prevents backsiphonage by creating an atmospheric vent when there is either negative pressure or subatmospheric pressure in a water system. It includes those devices permanently attached to a hose bibb ("hose bibb vacuum breaker").
https://www.municode.com/library/nc...nodeId=PTIICOOR_CH70UT_ARTVIICRNNCO_S70-578DE
A "backflow preventer" functions like a check valve whenever the downstream pressure is greater than the incoming pressure, which a "Vacuum breaker" would NOT detect or prevent.
Todd F
North Carolina
So in my situation where I want to attach a battery operated hose watering timer (see link below) to my hose bib and leave the water turned on so that it will irrigate while I'm sleeping - - 1) Can we agree with that the code says that I CANNOT DO THAT because the timer has an automatic shutoff valve that will be downstream of my hose bib anti-siphon valve
2) Is that because the anti-siphon is rendered effectively useless if its under continuous pressure/use?
3) And if that is true and my PRIMARY GOAL IS TO PREVENT BACKFLOW - - why can't I screw individual atmosphere vacuum breakers onto the 4 hose threads below the timer to protect each zone?
https://m.lowes.com/pd/Melnor-Digital-Timer/1000146765
Your Thoughts?
Thanks,
...Todd
