Need Help
Discussion in 'Water Heater Forum, Tanks' started by wmills, Jul 31, 2009.
  1. wmills
    wmills New Member
    Jul 31, 2009
    North Carolina
    We just closed on a house that our family loves. Just one problem, no hot water. I checked to make sure the power is run correctley. Checked the elements They were both good, replaced them with new ones anyway, worth the cost for the future. Still no hot water. I am now thinking in the way of replacing the thermostats. Cant be much else that I can think of. The tank is about five years and I think it is worth fixing instead of replacing. It is about thirty gallons underneath the house. I always hated water heaters under the house.
    Any ideas will be appreciated.
  2. jadnashua
    If there's power to the WH, then it's either the elements, or the thermostat, or, the water is turned off, or clogged up and can't flow. Do you get flow but it's cold?
    You need a meter.
  4. hj
    heater
    I am not a big fan of guessing why things do not work and just start replacing things until they do work. You would not let your car mechanic do that would you, (although a friend of mine did have something like that happen to her a few weeks ago, until I told her what the problem was and the mechanic fixed it). Test the elements, and thermostats, AND power to the heater before doing anything. Find out where the problem is and then fix THAT and nothing else. For example, you could have a burned out wire in the heater's junction box, if the heater has aluminum wire to it.
  5. wmills
    wmills New Member
    Jul 31, 2009
    North Carolina
    I am not a fan of just jumping into the change parts attitude. Turns out I had a circut breaker with one leg that was frying causing intermittent power. I replaced it and now it works great. I had changed all the parts Knowing that the parts are not that expensive and after draining the tank I wanted a fairly fresh start. Thanks for the help and sorry for not replying sooner but have been offline for a couple of weeks due to the move.
Similar Threads: Need Help
Water Heater Forum, Tanks Need help draining a State water heater Oct 26, 2016
Water Heater Forum, Tanks Need help..problem hooking up blower kit on BW Water Heater! Jun 2, 2016
Water Heater Forum, Tanks Water heater leaking, need help Apr 14, 2016
Water Heater Forum, Tanks New Homeowner .. Need help with a new water heater Sep 26, 2015
Water Heater Forum, Tanks Need help/reassurance my hot water tank is safe Jun 24, 2015
