need help with ferroli gas boiler question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by April Raine, Jul 23, 2008.
  1. April Raine
    April Raine New Member
    Jul 23, 2008
    I have a ferroli gas boiler but cannot figure how to work. No manual and see no model number. I want to set to heat water for bath only. Sorry I can't give more details
    I cannot find the model on http://www.ferroli.co.uk/products/Domestic.php but it has the letters ABS-FR on the inside of the flap which is opened to reveal controls
    I have turned off rads but bath not heating. what temp should it be to heat bath?50 degres enough? There is a little green light with a symbol of a tap over it, but this does not light up
    I do not know what kind of boiler it is combi or system? I do have a cylinder in the hot press
    At left i have a dial with ON/OFF/RESET
    In the centre there is a temp dial at 50 degrees
    Above that are 6 little lights above which are symbols inc a tap symbol. Some symbols light when boiler on the tap symbol does not
    To the right is the timer dial and right of that is a dial which says bar.
    I took a photo and can forward or upload if someone tells me how to upload?
    Thanks
    April
Similar Threads: need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
