Tomzim82
Hey guys I need serious help. Had a flood in my house twice now.. My electric hot water heater is leaking from the lower element.
The element is new along with the gasket. It's a 4,500 watt, long element that was replaced 2 days ago. I replaced it because the water heater was pouring water from around the element. I pulled the old element off (was only 90 days old) and put a new name brand element in. I tightened it as much as I thought safe.
I woke up tonight to a flooded bedroom again. Water is poring out of the lower element once again.
The element is good so what could be causing this?
Too much pressure? I notice as soon as I release the drain valve the leak stops. Obviously this instantly released the pressure. Could this leak be a sign of over pressure?
The temp is set at about 135-140 degrees F.
I'm a disabled veteran of the current wars and can't really afford a plumber.
Tank is less than 10 years old. 40 gal with two elements. Top seems to be ok.
Please give me ANY ideas to check, I'm at my wits end here!
