need help identifying a tool
Discussion in 'Electrical Forum discussion & Blog' started by r_2016, Apr 29, 2008.
  1. r_2016
    r_2016 New Member
    May 25, 2007
    Hi, I work in the electrical field with indicator panels that use series of light bulbs to make numbers, kind of what you might see at a baseball game. A coworker of mine has a tool that he uses to remove light bulbs where the globe has broken out and there is just the base in the socket. The tool looks like a pair of pliers but when you squeeze the handle the tip spreads apart instead of clamping. Does onyone know what this tool is?
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    It's a Broken Light Bulb Removal tool.
    http://www.drillout.com/easeout/
    Never seen one of those, but there are a number of hand tools designed that way -- circlip spreader tool comes to mind:
    While rummaging around the Web, I found a number of people recommending a potato as a fine broken light bulb removal tool. Just push the (raw) potato into the remains of the bulb base and twist.
    Removing the bulb is made easier if, in the first place, you squirt a lubricant on the bulb base before screwing it in. I use a spray designed for lubricating aluminum, but WD-40 or 3-in-1 oil work pretty well.
Similar Threads: need help
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need help with replacing these from the 70s! Oct 4, 2015
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
