Need advice on sprinkler valve
Thurman
Does any manufacturer make a 12v DC operated sprinkler (water)control valve that is 1 1/4" NFPT ported on both ends? My local big box stores certainly don't have them and before I go running around searching I thought I would ask. Thanks, David
Jimbo
San Diego, CA
You could easily use a 1½" valve an bush down to the 1 1/4". The bigger problem is why do you need to operate on 12 VDC?? Seems almost all irrigation valves are 24 VAC.
Wet_Boots
Sprinkler Guy
Metro NYC
What is the water pressure at this valve? There might be a standard valve that will work.
