Need advice for wall hung toilet
Discussion in 'Toilet Forum discussions' started by MCEscher, Mar 26, 2012.
  1. MCEscher
    MCEscher New Member
    Mar 22, 2012
    Manitoba
    Hello
    I need some advice regarding a wall hung toilet. I manage a community hall and although we have a designated handicap washroom, it is lacking in a few areas. One problem is that there is not enough room to properly turn a wheelchair around. I don’t have to meet ADA requirements but I want to do the best I can. What I am planning to do is pull the toilet out and install a wall hung toilet. What this will do is give me some room under the toilet for the swing radius of the footrests on the typical wheelchair.
    I am leaning towards a flushometer type probably a Sloan flushometer. (Although I could use a cistern inside the wall, I think I would rather keep the plumbing all exposed.) I also prefer an elongated toilet as this seems to be normal for handicapped washrooms. At the same time I need to keep the toilet as short as possible and as much clearance underneath as I can get to clear footrests.
    I want a 6L flush (I would not have a problem with a higher volume flush but I don’t think they are available any longer.) Quite a few 4.8L toilets seem to accept a 6L flushometer. I have a 1 ½†supply to the building so can supply a 1†line at 65 psi.
    The toilets that I have been looking at are: Crane Placidus US3346, American Standard Flowise 3351 001, Contrac/Clark 4762CEX, Proflo PF1731, and Ceralux VitrA 5425HET. But I really can’t find much in the way of recommendations or reviews from people who have actually installed any of these toilets.
    Can anyone give me a recommendation, or tell me if I should avoid any of these models? Also tell me if you think I am missing something or what to watch for.
Similar Threads: Need advice
Toilet Forum discussions Need Advice on Toto Toilet and Washlet Nov 10, 2016
Toilet Forum discussions Need Advice: 10-inch rough-in for small space Apr 23, 2016
Toilet Forum discussions Need advice on replacement toilet for restaurant Dec 28, 2015
Toilet Forum discussions need advice on replacing case 3000 Nov 19, 2015
Toilet Forum discussions Toilet related tenant problem - need advice on water leak usage! Apr 11, 2015
