need a different solution
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Alexdc99, Sep 30, 2006.
  1. Alexdc99
    Alexdc99 New Member
    Sep 17, 2004
    Ontario, Canada
    I have a chlorine injection system pumping in to two 120gl retention tanks. From there I have a 2x9 blue GE filter canister that filters out the oxidized iron and other solid that may be inthe line. Due to my higher iron levels in the water I have to change this filter out ever 2 to 3 weeks because it gets plugged up with all the iron particals. Is there some other pre-filter I can use that will last longer. You can always tell when it's needs changing by the large pressure drop in the water output.
    Thanks
Similar Threads: need different
Plumbing Forum, Professional & DIY Advice Backflow fitting needed? Is different metals acceptable? Aug 8, 2014
Plumbing Forum, Professional & DIY Advice Gas line-connecting different metals - Need guidance Jul 30, 2012
Plumbing Forum, Professional & DIY Advice Different Pop-Up length needed Dec 17, 2006
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
