Mysterious drip and diverter issues...
Maulydaft
TORONTO, ON
I'll try and keep this brief, but it's not a brief story!
Our condo is 5 years old. Recently had a problem where the water was coming out the shower and tub spout when showering. Emailed the plumber, worker put in a new spout. Cost $325 and took 5 min. Then the spout started dripping. We also noticed this new spout was no different than the old one. Messaged again. Owner said the dripping was probably the cartridge. But he put in a new cartridge in 2020... it seemed suspicious/not right to me. He offered to work at half pay to put in a new cartridge. I just couldn't buy it. Dripping didn't start until they came to fix diverter problem! Worker came, pulled up on the diverter and said there was nothing wrong (like he didn't believe me) but he replaced anyway (for free). Nothing different. All we can do is pull up on the diverter and then put the water on. I said to plumbing company owner "FYI I think this spout just needs diverter up first?" No reply.
I opened it up and put the cartridge and balancing unit in vinegar for a while. They LOOKED fine... but?? Didn't help.
Called American Standard. They said for sure it needed a new cartridge. Couldn't really say WHY a cartridge that's supposed to last 10-20 years only lasts 2. Anyway I put that in. Didn't help. Still have the drip and still have to pull up on the diverter before turning on water. The water also SOUNDS different with this new diverter problem. I can't really explain more than that! (I use to be sound designer, so I notice these things)
What the heck!? :/
(And I want a new plumber who's not going to charge me $325 for 5 min that doesn't even solve the problem :/)
Breplum
Licensed plumbing contractor
San Francisco Bay Area
If you mean by dripping, that there is water coming out of the tub spout when the valve is off, then that is related to the cartridge either being bad or mis-installed.
If the diverter tub spout leaks a little when the shower is on, that is normal. No diverter spout seals completely.
If it leaks a lot, then you need a new diverter spout.
It is as simple as that.
John Gayewski
Iowa
You could try pulling the cartridge and plugging it off. Then try to soak the interior of the valve body with a de-scaling solution.
Maulydaft
TORONTO, ON
Yes, it's the tub dripping when everything is off. I put the new cartridge in myself so I guess I could have mis-installed it but I was careful and it was pretty straight forward.... ??
I had also taken off the shower head to clean it - could I have screwed up something behind the wall if I'd twisted the stem if it?
Maulydaft
TORONTO, ON
This is a new cartridge now. I soaked the original (well, it was from 2020) and balancing unit and that did no good. (They LOOKED totally fine to me. Nothing like what you see on Youtube!)
John Gayewski
Iowa
I'm talking about soaking the pipe and valve body inside the wall. Fill from the shower arm.
If this is a diverter spout, then dripping is normal. The amount of dripping varies. My Delta drips less than most.
A diverter spout is one where you do something at the spout to switch to shower mode. If you switch between shower and tub at the valve in the wall, then you don't have a diverter spout.
Maulydaft
TORONTO, ON
Yes definately diverter spout. There was no dripping until plumber put in a new spout (to deal with the issue of the water coming out both shower and tub faucet). Now it drips like crazy - like will fill an entire bathtub in a less than day. We have to shut off the main water to deal until a professional comes in :p
Breplum
Diverter spout has absolutely NOTHING to do with dripping when shower valve is off.
While dozing off thinking about this, I just remembered: Some American Standard ceramic shower cartridges have a ceramic plate which stays in place often and sometimes does not come with the cartridge. That plate can get a hairline crack and the valve leaks until you replace the plate.
I bet that is what's going on. Even a "pro" who doesn't have experience with that cartridge plate could be oblivious.
Maulydaft
TORONTO, ON
Oh interesting! I didn't notice such a plate, but that doesn't mean very much since I am no expert in the least! It's AS 023529-0070A - don't know if you can tell looking if it's suppose to have a plate? There was a "plate" inside when I changed the cartridge but it didn't seem to have anything to do with the cartridge... it seemed to be made of brass...
Maulydaft
TORONTO, ON
That's def my cartridge!
Agreed, but I was looking at this sentence: "Recently had a problem where the water was coming out the shower and tub spout when showering. "
So I figured the complaint was about the spout dripping while the water was turned on. And that would be solely because of the spout.
If the spout drips an hour after the shower is off, that would be cartridge.
Maulydaft
TORONTO, ON
Yes we have the two problems now - diverting problem where the only way to get the water to come out the shower only is to hold the diverter up and THEN turn on the water, and then the dripping spout when the water is off. The drip started happening when the new spout was put on (to deal with the diverting problem)... it really is a big mystery! :eek:
