My Pex install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cybervex, Apr 29, 2008.
  1. cybervex
    cybervex New Member
    Feb 26, 2008
    IT Systems Administrator
    Southfield, MI
    How is this for a nice clean PEX install? Not quite complete, but getting there. The home build is taking forever as I am the the homeowner, builder, and all the tradesmen.
  2. gear junkie
    gear junkie Plumber
    Feb 14, 2008
    government
    Virginia Beach, IPC country
    Looks very nice. Is that a tankless water heater above the manifold?
  4. bombjay
    bombjay New Member
    Mar 11, 2008
    Very neat. Good job with the pex elbows.
  5. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Yes. It is a Takagi TK-3.
    I will post more pics as I finish the install. Its hard to get pics of the full utility closet as it is in a hallway.
  6. Gary Slusser
    Retired
    Jay, very nice job.
    Where are you putting the water treatment; like at least a water softener? Especially when you have a tankless water heater.
  7. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Do I need water treatment for city water? I am going to put a filter in the kitchen for the water/icemaker and maybe something at the sink. In my current home, which happens to be on the same block, we have no water treatment.
  8. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Thanks for the compliments so far!
    Not to bad for an IT Systems Administrator, if I do say so myself.
  9. Squ1rrel
    Squ1rrel New Member
    Dec 21, 2007
    Texas
    I am sure Gary will say to test the water first....But you may want that softener if you use a tankless, just to be sure...they have a nasty habit of clogging with whatever minerals may be in the water, reducing efficiency and pressure.
  10. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    I did buy the isolation valves so that I will be able to clean it as needed.
  11. Gary Slusser
    Retired
    Find the water company's web site and then their Water Quality Report and then hardness or total hardness. If they don't list hardness call them. Use the maximum figure and divide it by 17.1 to convert ppm or mg/l to gpg. If there is more than 3-4 gpg of hardness your tankless water heater warranty may be voided or not but, it won't work well for very long due to hardness scale build up. It is a very rare city water system that doesn't have enough hardness to justify a softener; that is more than 3-4 gpg of hardness. And there is no filter that will remove hardness and you don't need a filter if your water is always clear. There is no sense in filtering visibly clear water, is there?
    I sell softeners all over the US and find hardness in the mid 20 gpg frequently with some in the high 30s or higher in certain places.
    I have installed many softeners etc. in confined spaces and can tell you that you will have a tough time getting one to fit that small hall closet. So think on installing on the main before the manifold somewhere else. Like in the garage or outside if your area doesn't have hard freezing weather.
    BTW, to clean a tankless takes acid IF the coil is metal it can be damaged with only a few cleanings. It is not much fun and can be needed very frequently if the water is hard.
Similar Threads: install
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
