my new Toto Drake toilet is leaking - trickling
Discussion in 'Toilet Forum discussions' started by Jasmine123, Apr 17, 2007.
  1. Jasmine123
    Jasmine123 New Member
    Mar 29, 2007
    retired
    toledo
    My new Toto Drake toilet (4-days old) is leaking, and I'm guessing (as a non-professional) that the flapper contact is not making a good seal.
    (1) Water enters the open pipe in the middle of the tank that sits on top of the toilet, from a rubber hose coming from a bright blue plastic piece, and (2) The water level drops a little over an inch.
    Thiis continues in a sustained fashion until the tank is empty.
    There is a little slack in the chain that goes to the flapper.
    I have a Five Year Limited Warranty which gives an 888-number to call, but it's only 7:00 a.m. and I doubt anyone is there yet.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Have you disassembled the flapper ans inspected it and the flapper seat? You may find something simple like tape or something not allowing a proper seal.
  4. Jasmine123
    Mar 29, 2007
    retired
    toledo
    yes
    Yes, I inspected it and found no tape or anything that apparently would interfere with the seal. I did find a number "9" and "Toto" on the top of the flapper, which is a bright red.
    After the tank empties, I picked up the flapper with my fingers and let it drop. This produced a nice "thud" sound.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Did you run your finger lightly on the flapper seat to feel for any bumps / problems that might not be readly visable with the eye?
  6. Jasmine123
    Mar 29, 2007
    retired
    toledo
    yes
    "Yes," I ran my fingers around both the flapper and the plastic (white) flange at the bottom, in the middle of, the toilet tank. I didn't notice any bumps or "anything."
  7. Cass
    Cass Plumber
    Nov 12, 2005
    I would try a Korky flapper and see if it makes any difference.
  8. Jasmine123
    Mar 29, 2007
    retired
    toledo
    back to Normal
    Maybe lifting the flapper and letting it "thud" did the trick. Or did running my finger around the bottom flange and the bottom of the flapper bring about the desired results? For whatever reason, my new Toto Drake doesn't leak now, and things are back to normal.
    (I capitalized "normal" because a friend of mine was from Normal, Illinois and, on occasion, he did "get back to Normal.")
  9. Cass
    Cass Plumber
    Nov 12, 2005
    You may have inadvertantly knocked off what ever was causing the problem without knowing it
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Feb 21, 2017
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
