My Heat pump outside unit stop working
Discussion in 'HVAC Heating & Cooling' started by rabbit, Feb 7, 2009.
  1. rabbit
    rabbit New Member
    Feb 7, 2009
    I need some help.
    I just noticed today that the air from heating vent is cooler and it turned out
    that the heating is on aux heater, not the heat pump. There is no movement
    for the outside unit, no fan, no compressor, etc.
    The outside temperature is normal, by the way.
    I opened the cover for the outside unit and I see the Orange wire was broken due to rusting. I reconnected it and turned all power back on, still nothing happened.
    I checked that the power to the unit is ok. I don't have multimeter so can't tell if the RED is providing 24v or not.
    The unit is two year old, Goodman GSH13 Heat Pump
    13 SEER / 7.7 HSPF Efficiency
    Anything else that I should look at? I live pretty far away from town and it is really expensive to get a technician to look at it. I will try my best first.
    Thanks a lot!
  2. wondering
    wondering Member
    Dec 10, 2006
    Alabama
    Check your booklet for the warranty. Then call your installer and have him check it out. I also had an issue with mine last year which was 2 years old and I called the installer and he came out and didnt charge me anything. Mine is a Goodman. Not sure about the labor warranty now, I would have to go get my book but I know mine has a lifetime compressor warranty.
Similar Threads: Heat pump
HVAC Heating & Cooling Rheem heat pump Nov 27, 2016
HVAC Heating & Cooling Start up noise Heat Pump Aug 21, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Odd Heat Pump Behavior Feb 3, 2016
HVAC Heating & Cooling Multi zones HVAC system not pumping heat to first floor Mar 23, 2015
