Moving Toilet
Discussion in 'Toilet Forum discussions' started by tomyco, Oct 24, 2007.
  1. tomyco
    tomyco New Member
    Oct 24, 2007
    I am looking into remodeling our master bathroom. I would like to move the toilet to the other side of the room but I was told moving a toilet is very expensive.
    Can someone give me an idea of how much this would cost to move a toilet to the other side of the room. Are we talking a few hundred dollars, $500, $1000, more?
    What makes it so expensive. Thanks!
  2. jadnashua
    The drain lines are big, you'll have to either tear the floor off or the ceiling, it needs to be sloped back to the main drain line, so depending on where it is and how the joists run, you may have to box out a section since you can't cut that big of a hole in all of your joists.
    If you are lucky, the drain line runs from where you want to put it, so it won't be a big deal other than tearing up things to be able to get to it.
    It could be anywhere from a couple of hours to much longer, not counting putting the floor back down, or fixing the ceiling, or building a chase to hide the pipe if it needs to be run below the joists. Then, you've got to move the water supply...could be nearly as much fun.
    I had mine moved during a remodel along with moving the tub and sink. SPent about $1200 on just the rough-in, and I had the floor torn up and all of the old stuff removed so they had as clean a slate as possible. This included having most of the drywall off the walls and the subflooring torn up. If I had to pay them to do that, and replace it, it would have been probably tripple that.
    Plus, you have to run a vent line from the new toilet location either around the room or up into the ceiling or attic to rejoin the rest of the vent system.
Similar Threads: Moving Toilet
Toilet Forum discussions PICK UP STIX, A tool for moving and picking up toilets Jul 12, 2016
Toilet Forum discussions Moving toilet pipes Feb 15, 2015
Toilet Forum discussions Need help moving toilet Feb 19, 2014
Toilet Forum discussions Is there a way to replace closet bolt without removing the toilet? Dec 26, 2013
Toilet Forum discussions Moving toilet 1-2 inches Aug 23, 2013
