J Blow
This is a pretty common question and the fact that I've read many of them and don't see the option I'm hoping for makes me think it isn't one...but here it goes.
I moved a double sink vanity about 6-8 inches so now the wall drain location is just far enough away that the J trap won't adjust enough to connect without some reconfiguration. It's the standard setup with a trap adaptor, tailpiece, etc. It seems the 'proper' solution is to remove the trap adapter and replace it with a 22.5/45 elbow but with such cramped working quarters I was hoping to find some sort of 45 degree joint that connects to the trap adapter via slip joint so I can then connect the tailpiece through that. I'm assuming this would be some sort of double slip joint unit as I've found the elbow below but wondering if I'm using it properly or that's not an intended application.
https://www.supplyhouse.com/Oatey-P9665-1-1-2-x-1-1-2-45-Double-Slip-Joint-Elbow-White
