Moving, reducing and changing 4" cast iron vent pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jbclem, Dec 9, 2004.
  1. jbclem
    jbclem New Member
    Dec 3, 2004
    I have a 4" cast iron vent from my toilet (with one sink vent going into it) that goes straight up to the roof (1 story bldg). I would like to recapture some of the space it goes through so I'd like to cut it, convert it to ABS, run it horizontally about 24 inches, up about 48", then another right angle back to join the original cast iron just below where it goes through the roof.
    There are some questions I have about doing this...
    1. Ok to run the toilet vent horizontal for 2 feet?
    2. What's the best kind of adaptor (cast iron to ABS)?
    3. Can I use either black or white(thiner) plastic pipe?
    4. Can I reduce the plastic pipe down to 2"?
    5. Will the adaptor(s) become a weak spot over time, subject to leaking and smells?
    6. Should I continue with the plastic pipe up through the roof, instead of reconnecting to the cast iron pipe?
    7. Ok to cut and adapt the cast iron pipe around the level of top of the toilet tank?...it's a standard 2 piece toilet.
    That's all I can think of right now, but I'd appreciate any advice, especially if someone thinks this is not the correct way to do this.
    John
  2. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Elbow Above Lavatory
    Your first fitting should not be until 6" above the floor level rim of the highest fixture served. This would be your lavatory. A no-hub clamp connection would not be a week point. You can install bends in your vent but the piping should grade downward. Reconnection to the cast iron at the roof is okay. You may be able to reduce the size of your vent but it depends on the total vents serving the house. You have to have the same vent area as the house drain which is four inch. If you have two other two inch vents you may be able to reduce. Schedule 40 pipe is the same size outside diameter. You cannot use thinner wall pipe. PVC (white) and ABS (black) are the same size.
  4. hj
    vents
    Everything okay until you got to the reduced pipe size. He would need four 2" roof vents to equal a 4" main sewer pipe.
  5. LonnythePlumber
    Sep 6, 2004
    Wichita, Kansas
    3+2+2=4
    I meant reducing the main stack to a 3" if he has two 2" vents now. Two 2" is 6.28" plus the 3" at 7.06 is 13.34" which satisfies our 4" 12.56 requirement for aggregrate cross-sectional area.
Similar Threads: Moving reducing
Plumbing Forum, Professional & DIY Advice Removing Bonnet - Pressure Reducing Valve Mar 4, 2005
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
