Molded PVC Shower Pan Repair
Discussion in 'Shower & Bathtub Forum & Blog' started by wexcellent, Apr 29, 2007.
  1. wexcellent
    wexcellent New Member
    Apr 29, 2007
    PVC Shower Pan Repair - someone!? Anyone!?
    The place I moved into has a 4 piece, pvc, neo angle shower unit in it. The pan is made of molded PVC and was not properly supported underneath. As a result the PVC broke and split in the middle of the floor. It is about a 5" split in a straightline. The drain flange is still intact and the split comes to within an inch or so of it. It is slab on grade construction and there is no sign of moisture around the shower base (I have a good moisture meter) so any water leaking must be going down in the cutout around the shower drain which was never patched in with concrete.
    I think I can slip adequate support into the area by unscrewing the drain and lifting up the pan a bit. What I'm wondering is if there is someway to patch the crack with thicker pvc material that I could adhere over the top of the break after prepping the area. I can't find anything online. This is a basement shower and I don't really care if the shower pan is pretty. I just want to stop the leak and prevent further cracking of the pan.
    Any help would be appreciated.
    The only alternative I see is to replace the whole thing but that probably means wall panels and glass too because I think it must have come as a kit and I doubt I could match the pan size.
    Thanks,
    Steve
  2. wexcellent
    Apr 29, 2007
    Still no Responses?
    Is there really no answer to this other than replacement? No one out there with experience on these?
    Steve
  4. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    I have never heard of any method or repair for these...
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    PVC can be heat welded, I have done it, and you can fix that crack. If you are familiar with gas welding, the principles here are the same: hot air, filler rod, technique.
    Talk to an auto body repairman or check at a couple of auto parts stores. The tool you need is essentially a soldering iron with air passing through it and the filler rod you need will be PVC.
    What I would probably do there would be to leave the drain alone and carefully pry one side of that crack up (open) so I could inject grout for support under the pan. Your local masonry store should be able to supply a smooth grout, and there are various ways to inject it. I have done some with an actual grout pump -- do a web search -- and I have also done some with a squeeze bag and nozzle similar to what cake decorators use, but actually for grout. A pressure pot would be another way, or maybe even a grease gun.
Similar Threads: Molded Shower
Shower & Bathtub Forum & Blog Bath tub not molded correctly? Jan 27, 2006
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Monday at 7:02 PM
Shower & Bathtub Forum & Blog Do all neo-angle showers have the same relative dimensions? Monday at 8:46 AM
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Old delta shower valve not working Saturday at 6:30 AM
