Moen Tub Faucet Shower Pull No Longer Works
Discussion in 'Shower & Bathtub Forum & Blog' started by SteveOr, Dec 24, 2009.
  1. SteveOr
    SteveOr New Member
    May 10, 2006
    I have a Moen shower and the pull on/push off valve on the tub faucet no longer works very well after four months of non use. I've tried to search this forum for this issue but I'm not sure if I used the right search terms. From what I can see the rod pulls up a plastic plate which closes off the faucet sending the water up to the shower. Apparently there is no longer a tight seal. Anyone know of a quick remedy vice replacing the entire faucet head?
    Thanks, Steve
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    It sounds like you have a "push buttom diverter". 3 options you can do
    1) unsrew the diverter fro m the valve body and clean it with vinegar and water, then lubricate with silicone grease
    or
    2)Call moen, 1-800 number and explain your problem. They may send you a new diverter free of charge
    or
    3) abandon the diverter and replace your spout with a diverter spout (I don't recommend this, but its an easy fix)
  4. jimbo
    jimbo Plumber
    San Diego, CA
    It is not a pushbutton diverter, it is a diverter tub spout. Generally, they are not repairable. You could do as suggested and spray some white vinegar up into the nose and let it soak., then operate the pull-up button several times with water running.
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    My bad, I misunderstood.
    Replacement of the diverter spout is probably the best option in this case
  6. SteveOr
    SteveOr New Member
    May 10, 2006
    The call to Moen did the trick. They sent me a free diverter repair kit which contains a pull knob, plastic faceplate, gasket, and directions. 1-2-3 and back to full shower pressure. Thanks.
Similar Threads: Moen Faucet
Shower & Bathtub Forum & Blog Moen tub faucet cross member broke Dec 3, 2016
Shower & Bathtub Forum & Blog Looking for Moen Brand faucet parts (1950's) Oct 14, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Moenique, Help with shower faucet Aug 12, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
