Moen positemp problem - clogged??
Discussion in 'Shower & Bathtub Forum & Blog' started by kool_bean, Jan 12, 2009.
  1. kool_bean
    kool_bean New Member
    Jan 8, 2009
    Water flow in my shower was slowing down and it was also beginning to drip. Figured it was time to replace the Moen posi-temp cartridge. From past experience, I knew that these were difficult to remove and so I had a plumber come out.
    He used the Moen puller and broke the inner metal part of the cartridge but was able to remove the rest of the plastic cartridge in bits in pieces. It all finally came out! Flushed out the posi-temp valve to clear out any debris and there was good water flow. Installed a brand new cartridge, turned on the water but no water! Tried two new different cartridges, still no water!
    He blew into the shower head arm and was unable to get any air through. He concluded that there was some obstruction in the posi-temp valve. He tried blowing 100 psi of compressed air in through the shower head arm but it did not clear the blockage.
    Question:
    Has anyone seen this type of blockage problem before and is there any way to clear it out? Is my only option to replace the entire valve?
    Thanks, any advice is appreciated.
    [​IMG]
  2. McMike
    McMike Plumber
    Jan 4, 2009
    plumber
    Aurora IL
    lost bit of rubber
    likely part of the black rubber rectangular gasket sheared off and is lodged in shower port of valve, you will need a strong o ring pick and maybe a new cartridge to fix, you first need to turn water off to faucet, disassemble faucet, with cartridge removed there will be a port at 12 o clock inside of where the cartridge goes, poke and pry up in the port with a good quality o ring pick to dislodge rubber bits, reassemble faucet and all should be good as long as pressure was good before starting, if not there may be a mineral deposit build up in this area, moen faucets are really nice in that there are few moving parts to go wrong
    [​IMG]
    Moen replacement 1222 for the Posi-Temp Shower Valve
Similar Threads: Moen positemp
Shower & Bathtub Forum & Blog Shower remodel layout. Two Moen Positemp Valves Jun 5, 2016
Shower & Bathtub Forum & Blog Leaking Moen Positemp Jun 13, 2009
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Mar 16, 2017
Shower & Bathtub Forum & Blog Help appreciated! : stripped Moen retainer pin / clip Feb 25, 2017
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
