Moen Models? Posi-Temp
Discussion in 'Shower & Bathtub Forum & Blog' started by dkdaniel, Jan 29, 2011.
  1. dkdaniel
    dkdaniel New Member
    Jan 29, 2011
    Iowa City IA
    Hi All! I've been researching how to repair my Moen shower faucet. I've found many helpful online videos on fixing the Moen model 1220 or 1225. My problem is that my cartridge-based valve doesn't look like that. Mine does not pull out before it turns. It simply turns and mixes the water cold-to-hot as it travels thru its arc. Upon removing the handle, I see what is probably a cartridge covered with a white plastic/nylon part combined with a brass insert with a set screww that allows the mix ratio to be adjusted. What am I looking at here? I have not found any other Moen model online that looks like this. I'll appreciate the help as my water bill is up 50% because of the leak.
  2. jimbo
    jimbo Plumber
    Sounds like you have a positem. There are lots of trim varieties, but this diagram shows pretty much how it all goes together:
    http://www.moen.com/shared/pdf/l82691pt.pdf
    Remove the sleeve ("stop tube") and after turning off your main water, pull out the retaining clip. You will probably need a Moen cartridge puller, which is available at the same place you will buy the new 1222 cartridge
    [​IMG]
Similar Threads: Moen Models
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Moen s3600 valve cartridge removal Dec 10, 2016
Shower & Bathtub Forum & Blog Moen tub faucet cross member broke Dec 3, 2016
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
