Moen cartridge stuck
Discussion in 'Shower & Bathtub Forum & Blog' started by scorpsista, May 9, 2009.
  1. scorpsista
    scorpsista New Member
    May 9, 2009
    I had my Moen valve stuck in August. A Plumber came out, removed the old cartridge and replaced with a new one. He used the same handle that had broke the cartridge, and when I say broke, the handle broke off at the stem of the cartridge. Today, 9 months later, it's stuck again. I think he should have replaced the handle, because the current handle is old and sits on the cartridge valve wobbly. Is there a way to loosen up the cartridge with some kind of lubricant? I am guessing it got stuck again because of mineral deposits. Do I need to have the valve replaced now? Also, the cartridge never turned all the way, I never got the hot water I used to have, and it has a constant drip. Any help would be appreciated. Thank you.
  2. plumbingskool
    plumbingskool Retired Tradesman
    Feb 25, 2008
    Not Sure ;-)
    NY
    Your going to haVE to replace the handle and the cartridge this time,
    It's just not worth it to try to "band aid" the cartridge ( Lubricating it)
    I would also suggest having a plumber install a water filter if you know you have lots of minerals in your water.
    Hope this helps, This is only my opinion, I am sure you will gets several:)
Similar Threads: Moen cartridge
Shower & Bathtub Forum & Blog Moen s3600 valve cartridge removal Dec 10, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp replacement cartridge M1222B Oct 31, 2014
Shower & Bathtub Forum & Blog Moen Cartridge back piece of housing broke. Help Please! Mar 30, 2014
Shower & Bathtub Forum & Blog moen posi temp cartridge issues Dec 8, 2013
