Mixet Shower Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by smokeybear, Dec 23, 2007.
  1. smokeybear
    smokeybear New Member
    Dec 23, 2007
    Where can I find a manual on how to adjust this. My problem is I can't get the Temp handle to sync. with the flow valve
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    There's manuals? Geez, I've been doing it the hard way.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    NOT! But what do you mean by not "sync" on the handles? Mixet is long out of business, so there is no support, but parts are still available.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You and ten million others have a problem with Mixet. You will need to change out the cartridge and any other bad parts, or, better yet, replace the entire shower manifold with a Delta or Moen.
  6. David here
    David here New Member
    Dec 18, 2007
    Sync? The temp handle should turn independently of the flow control knob. If the temp handle turns a full circle, perhaps someone who worked on it lost or left out a "key" that should act as a stop. You might find packaging on a new stem part that has a diagram and some brief instructions.
    In any case, don't expect good temperature control from these Mixet valves. Experiment with settings in hope of finding a good temperature.
  7. hj
    Mixet
    Only the "old" long pattern stem had the stop "C" clip, and it is usually thrown away when the stem is replaced because it serves no useful function. As far as syncing the temperature and flow, we would have to know what you mean by that. The instructions for the valve are;
    1. Turn on the water to the desired flow.
    2. Turn the temperature lever to the desired temperature.
    Those are the only instructions needed for that valve.
Similar Threads: Mixet Shower
Plumbing Forum, Professional & DIY Advice Mixet Shower, DIY professional plumbing repairs Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Mixet shower faucet question... Jun 7, 2009
Plumbing Forum, Professional & DIY Advice Mixet tub/shower valve questions... May 4, 2008
Plumbing Forum, Professional & DIY Advice Tired of Mixet shower handles Apr 21, 2006
Plumbing Forum, Professional & DIY Advice mixet shower control valve jammed Mar 31, 2006
