Mini Split ducting inside walls
Discussion in 'HVAC Heating & Cooling' started by bigwooo, Sep 8, 2009.
  1. bigwooo
    bigwooo New Member
    Sep 3, 2009
    Retired Firefighter
    BCS Mexico
    I'm about to start building a new home. Right now I don't know if I will be installing AC or not. If I do, it will be a mini split unit in a couple of the rooms.
    I'd like to avoid having the tubing etc. running up the outside and through the walls, instead, in case I do install the AC later, I'd like to design the house with conduit pre-installed in the walls from where the wall units will be located down to where the compressor will be.
    I can't find any information on what size conduit I should install to accommodate the wiring, ducting etc for the run from the wall unit to the compressor.
    Any ideas?
Similar Threads: Mini Split
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling Mini-Split help Jun 10, 2016
HVAC Heating & Cooling Mini-split p-trap May 30, 2016
HVAC Heating & Cooling Ductless Mini Split Cooling Design Apr 27, 2016
