Metal straps on ABS pipe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by David Meiland, Oct 1, 2006.
  1. David Meiland
    David Meiland General Contractor
    Apr 29, 2006
    General Contractor
    Friday Harbor, Washington
    I bought a couple of boxes of 2" and 3" C-shaped pipe straps from Keller. When I opened them they turned out to be galv steel. I'm going to be running ABS drains and am not sure that metal straps are OK on plastic pipe. The salesman I buy from is generally right on as far as what he sends out to me, so I assume that's what he's sending everyone. What are pros using?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    The metal straps will be fine as long as when you hang the pipe it doesn't pull the pipe up from the drain angle.
  4. David Meiland
    Apr 29, 2006
    General Contractor
    These would generally be used where the pipe is vertical and against a stud. I have the correct hangers for running underfloor.
  5. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    they will work good.
Similar Threads: Metal straps
Plumbing Forum, Professional & DIY Advice Metal roof- vent flashing, small ones for 2" & 1.5" Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
Plumbing Forum, Professional & DIY Advice FALLING DOWN c1966 rimless undermount sink, clips to metal bezel Jul 29, 2015
Plumbing Forum, Professional & DIY Advice Buried Fernco/Mission coupling - use metal banded or all rubber? Aug 15, 2014
Plumbing Forum, Professional & DIY Advice Backflow fitting needed? Is different metals acceptable? Aug 8, 2014
