Maximum time between regens with clear water iron
Discussion in 'Water Softener Forum, Questions and Answers' started by dfasdf45, Dec 29, 2009.
  1. dfasdf45
    dfasdf45 DIY Junior Member
    Dec 29, 2009
    Ontario, CA
    Hi,
    Is there a recomended maximum time between regens when clear water iron is present? I have 20gpg hardness with 2ppm iron.
    Thanks
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    How many people in the house.
    Size of unit that is in question.
  4. dfasdf45
    Dec 29, 2009
    Ontario, CA
    2 people
    30k unit
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    If it is a control working with a day clock, going every x number of days, and using 60 gallons per person per day.
    I would set the unit at every 6 days, if you are using 9-12lbs per cleaning.
    If you have it at 6-8lbs, then every 4 days.
    That is what I would be setting one of my customers at. If it was running on gallons, then 800gallons.
  6. dfasdf45
    Dec 29, 2009
    Ontario, CA
    If it is a flow based control with a max days between recharges, then should I let the flow control trigger the regen with no max days between recharges?
    In other words, is it better to have a maximum number of days between recharges enabled when clear water iron is present to prevent possible long term fouling of the resin?
    Thanks
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    What control are we working with?
    What brand is this unit?
  8. Gary Slusser
    Retired
    You should be looking at a 1.5 cuft instead of a 1.0 cuft. Otherwise your salt efficiency for your 27k of regenerated capacity is not going to be very good. Plus you pick up 3 more gpm in the constant SFR.
    How many bathrooms and any large tubs or two person showers or any body sprays?
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    That or how many are Teenagers.
    Over the long run you are right, the 1.5 cubic has lower salt usage and will do a better flow rate.
  10. dfasdf45
    Dec 29, 2009
    Ontario, CA
    it's an ecowater control.
    currently using 70-100 gallons per day and recharging appoximatly every 8-9 days. We are well within the SFR for this unit.
    With 2ppm iron should I be using the calendar override to force a recharge sooner to help preserve the life of the resin from excessive iron oxidization?
    I intend to run a resin cleaning 2-3 times a year.
    Thanks
  11. Akpsdvan
    Dec 29, 2009
    Alaska
    If you set the day override for 8 or 9 days, and still have the meter counting to take over if you have a larger number of people in the house, that should work.
    What is the water temp coming out of the well and into the house?
Similar Threads: Maximum between
Water Softener Forum, Questions and Answers Maximum backwash hose length at 1/2" Oct 5, 2016
Water Softener Forum, Questions and Answers Maximum PSI intake for Kinetico 2175 Jul 9, 2014
Water Softener Forum, Questions and Answers Programming an 5600SXT for maximum effenciency Nov 11, 2012
Water Softener Forum, Questions and Answers Need help to decide between WS1 or 2510SXT Sep 14, 2016
Water Softener Forum, Questions and Answers Trying to choose between water conditioning options Jun 24, 2016
