I'm nearly finished with my DWV and will be starting on the supplies this weekend. I'll be using Uponor PEX A. A couple of prelim questions.
1. The two supplies for the single vanity run under the floor and then a short distance up the wall. I was going to cut the copper under the floor as close to the wall as possible and still run the double vanity lines. However, I noticed that in one spot the copper has oxidized a good bit. Is this an issue? I start my PEX runs before those spots.
2. It looks like there was a leak in the 3/4 cold water line at some point and a repair was made from the back vanity using a shark bit. I suspect the tight quarters was the reason. Is this something I should repair with a sweat joint? I've not sweated copper before (will be learning and practicing) so trying to do as little as I have too. Plus this seems pretty close to the wood as well for sweating. Can it be left as is?
