Mansfield Toilet Question.........
Discussion in 'Toilet Forum discussions' started by Marc46, Feb 25, 2010.
  1. Marc46
    Marc46 HVAC Contractor
    Jul 27, 2008
    HVAC Contractor
    Central Florida
    Can somebody tell me where the water level mark is on what I believe is a 160 tank?
    I replaced my mothers flush tower seals again the other day, and had to adjust the level on one, as it was filling too high and running back down the top of the flush tube before shutting off.
    I looked all around in the tank when it was drained and could see nothing. Her tanks are very clean BTW,......almost like new.
    Wondering if they go by one of the rings on the flush tower, or a measurement from the top of the tank.
    I would like to set them to the proper level if I could find it!:cool:
    Thanks.
  2. jadnashua
    Some don't have a water line. In that case, about 1" below the lip on the overflow tube is usually about right. Many (not all) toilets use a timed flapper, either by a weight, calibrated holes, or some other means to close them at the desired time as most modern toilets do not normally empty the tank as those of old.
  4. maddog
    maddog Engineer
    Aug 1, 2006
    Software Engineer
    near San Jose, CA.
    I'm not a pro - but my house came with 3 of these bad boys. If you have the original ballcock and float ball, the float may have taken on some water or the adjustment screw on the ballcock has gone out of whack. Some people just bend the rod a bit to lower the float ball and make it shut off sooner. A better fix is to replace the ballcock with a Fluidmaster 400A fill valve (less than $10 at HD, Lowes or ACE). It's an easy switch and the water level adjustment is very simple. I also got tired of replacing the seal on the flush tower, and replaced it with the Fluidmaster flapper-type flush valve. It's not too difficult for a diy'er, but you do have to remove the tank to make the change. The Mansfields were basically maintenance-free after making these changes, but they still clog a lot.....
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Use the line on the flush tower...
  6. Marc46
    Jul 27, 2008
    HVAC Contractor
    Central Florida
    Thanks guys,.....I did use the second line down on the flush tower, and all is well.
    Just wanted to be sure.
  7. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    The tank has a marking at the back that says "Waterline"
Similar Threads: Mansfield Toilet
Toilet Forum discussions A close look at the Mansfield Cascade rimless toilet -PICS- Jan 8, 2013
Toilet Forum discussions Has anyone seen this relativity new Mansfield rimless toilet? Nov 18, 2012
Toilet Forum discussions Mansfield 1983 Toilet: Tank to Bowl Gasket Nightmare Jun 14, 2011
Toilet Forum discussions Need help choosing a Toto..or Mansfield toilet May 18, 2011
Toilet Forum discussions Mansfield toilet overflows Nov 22, 2010
