Make chrome trap to sani-T connection look nice
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jwray, Jun 22, 2005.
  1. jwray
    jwray New Member
    Oct 25, 2004
    Virginia
    Will be installing a wall hung lavatory where the drain and supply will be exposed. I would like to use a tubular (cast or drawn) chromed brass trap/trap arm to make it look nice. I would like to do it so little to no PVC is showing.
    How can the trap to sanitary T connection be accomplished without any PVC showing?
    I should mention that the bath is a new bath will walls gutted and I have not yet installed the rough in DWV so I am starting from scratch here and can use whatever option is best.
    Thanks,
    Joel
  2. hj
    tee
    You install the tee in the wall so it is far enough back that it does not project through the finished wall. Then when you place the lav in position, you put a "street" trap adapter, or a female one with a piece of pipe, depending on how far the tee is inside the wall. Then insert the trap into the adapter with a slip nut and a chrome deep, or "bell", escutcheon to cover the connection.
  4. jwray
    jwray New Member
    Oct 25, 2004
    Virginia
    slip nut / adapter material?
    Thanks HJ
    Are the trap adapter and slip nut both PVC even with a metal trap arm?
    I didn't think about hiding it with an eschuteon (sp?)!!
    Thanks for the advice.
    Joel
Similar Threads: chrome trap
Plumbing Forum, Professional & DIY Advice Chrome p-trap question Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Existing 1 1/4" chrome plumbing trap retrofit. what would you do? Nov 1, 2015
Plumbing Forum, Professional & DIY Advice Connect existing black ABS to new brass (chrome finish) trap Jun 4, 2014
Plumbing Forum, Professional & DIY Advice Replace chrome trap arm under kitchen sink Aug 7, 2011
Plumbing Forum, Professional & DIY Advice Chrome P-traps Apr 6, 2011
