Main Service Panels separate neutrals but multiple grounds in bus bar
Discussion in 'Electrical Forum discussion & Blog' started by Mr_Magoo, Sep 21, 2008.
  1. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    I just want to confirm that in my main service panel I am suppossed to put the neutrals in individual holes of the bus bar but multiple (2 or 3) grounds can go in an individual hole. Is this correct?
    Thanks,
    Mike
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    No
    Service panel:
    Grounds and neutrals on same bus.
    ONE neutral per hole
    Multiple grounds per hole if the bus is listed for multiple grounds.
    Panels other than service panels ("sub panels"):
    Neutral bus isolated from ground bus.
  4. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    Thank you. I worded my question poorly and you confirmed my understanding of one neutral per hole. How would I know if the bus bar is rated for multiple grounds per hole? It is a SquareD Homeline Entrance Panel. I don't think there are enough holes in the bus bar for each ground and each common to get their own hole.
    Thanks,
    Mike
  5. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    I've never seen any rating that mentioned multiple wires in each hole. If you've run out of space for ground wires, you can get add a lugs from an electrical supplier.
    And Alectrician is right, the netural and ground are bonded together at the main panel but not at any sub panels to avoid return current from sub panels from using the ground as a neutral return path. But around here, the grounds are all terminated on the grounding bus bar and the neutrals are all terminated on the neutral bus bar but the neutral bus bar is just bonded to the panel with an optional screws that's included with the panel.
  6. pudge565
    pudge565 New Member
    Dec 30, 2007
    Normally if it is rated for 2 grounds per hole it will be egg shaped and not round. You are only allowed 2 per hole if properly rated. No more than that.
Similar Threads: Main Service
Electrical Forum discussion & Blog Main lug as a primary service panel Jan 5, 2008
Electrical Forum discussion & Blog Main Power Supply Move Jun 23, 2016
Electrical Forum discussion & Blog Extending ground wire from main panel Jun 11, 2016
Electrical Forum discussion & Blog Two MC cables into one knockout on main panel? Jun 11, 2016
Electrical Forum discussion & Blog Does a sub panel in attached space need a main breaker? Feb 20, 2015
