main drain line sizing?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mporterf, Mar 20, 2008.
  1. mporterf
    mporterf New Member
    Mar 17, 2008
    I live in georgia and I am trying to plumb my own house, what is the min. size drain line under the house (crawl space). I know that from the house clean out to the septic tank should be 4", is the entire horizonal drain require to be 3" or 4"?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Either 3 or 4" is commonly used. Check with your local authorities.
  4. hj
    pipe
    It depends on your local regulations and the number of toilets in the house. Here if 3" is adequate it can run all the way to the septic tank.
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Here, we're required to run 4" out under the footing, but other parts of the state have overlooked it and allowed 3" depending on toilets. 2 toilets = 3" required pipe size, and if one toilet is more than 15' horizontally from the others, 3" is allowed. But the pipe through the footing still has to be 4".
    Codes vary greatly on this, I'm sure. Personally, I'd want that third toilet to be piped into 4" even if I didn't have to, but I'm old-fashioned. :)
  6. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    What kind of house are we talking about. We could be looking at anywhere from a 3" building drain to 6" plus. Is this a 1 bath rambler or a 12 bath mansion.
Similar Threads: main drain
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Jog in Main Drain Sep 18, 2016
Plumbing Forum, Professional & DIY Advice Toilet drain to merge in offset part of main stack? Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Main drain cleanout worn can't get a wrench on Jul 3, 2016
Plumbing Forum, Professional & DIY Advice Swimming pool main drain Apr 24, 2016
