Machinist Round pipe dies vs Racheting Pipe Dies
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Its.me.again, Feb 25, 2013.
  1. Its.me.again
    Its.me.again New Member
    Oct 12, 2012
    Buffalo, NY
    I want to ask about pipe dies for home use. To use dies occassionally to clean up threads on fittings....whether it be for gas or water line. Cleaning up threads on black pipe, galvanized, brass or plastic. For home use it would be small pipe, from 1/4" to 1" size. Also, might cut a new thread in black pipe once in a while.
    I am buying a set of round dies and some round pipe die stocks handles to accomodate 1/4 - 3/4 npt sizes. Will these (Chinese-made) be able to cut new threads in black pipe OK for occasional use?
    I am disgusted with the racheting pipe die kits I have seen. It seems you have to spend a lot and buy Ridgid to get good ones. And also- the rachet kits come in BIG die sizes. I mean , why would I need 1 1/2" npt? Also the rachets seem to have big clicks and not smooth motion. Are these cheap racheting pipe dies hard to start a thread with? All the reviews on these cheap kits seem bad.
    Is it the right option to opt for round dies?
Similar Threads: Machinist Round
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Above Ground, Outdoor Sewage Pump System? Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Pipe leak at water shut off or ground water? Nov 1, 2016
