Maax drain install question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jadedpuppy, Jul 1, 2013.
  1. jadedpuppy
    jadedpuppy New Member
    Jul 1, 2013
    Oregon
    I bought a Maax acrylic shower base and am a little confused about the drain installation.
    The shower base I bought is here: http://www.maax.com/en/utilitypages/productdetail.aspx?productID={C3A12DE8-1882-4771-8D07-BB91ED74E1CF}
    Here is the install instructions: http://www.maax.com/~/media/docs/Installation guides/10029775_2012-06-28.pdf
    If you open up the install instructions, you will two figures on page 8. Figures B and C. In figure B, it looks like the black rubber gasket goes on top of the shower base and hte cardboard gasket goes under the base. But in figure C it looks like both the cardboard and rubber gasket go under the shower base. Obviously both cannot be correct.
    The instructions seem to indicate that figure C is the correct depiction. Here is the quote: "Install rubber gasket then cardboard gasket on the top part of the drain coming out under the base." If that is correct, this means that the seal is accomplished only with the caulking on the top of the base? Is that correct?
    Any help would greatly be appreciated, I am not a seasoned plumber by any stretch :)
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Both gaskets go on the bottom. The rubber gasket comes in contact with the bottom of the base the cardboard gasket goes under the rubber gasket. It acts as a friction ring to prevent the rubber gasket from spinning when you tighten the nut.
    John
  4. jadedpuppy
    Jul 1, 2013
    Oregon
    Thanks for the reply.
    The rubber gasket would not spin though, since the bottom section of drain is glued to the PVC pipe leading into the trap. So the "nut" part of the drain (the female part with the threading) stays in place below the shower base itself. The male part of the drain is the only part that spins. Maybe I'm not understanding you though?
    Doesn't that mean that the only seal is the caulking then? Isn't that kind of bad? (Again, sorry for my lack of knowledge regarding this, maybe this is normal for shower drains)
    Would I then replace the caulking every year or so?
  5. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Taken from your instructions...
    "Screw bottom part of drain on top part of drain under the base."
  6. jadedpuppy
    Jul 1, 2013
    Oregon
    Ah, so your saying that I shouldn't have glued the bottom part to the PVC already? Yeah, maybe that is what they meant in the instructions. Screwing in the "male" (top) part though won't really make a difference though. It's the same thing really.
    My question/problem about the caulking being the only real "seal" still stands though. Is that normal for drains?
  7. hj
    Actually, because of the way the drain appears to be constructed, the entire seal is the rubber gasket between the bottom of the shower and the top of the drain "body". Any leakage at the caulking would just flow into the drain body.
Similar Threads: Maax drain
Plumbing Forum, Professional & DIY Advice Which Mortar for Bed for One-Piece Maax Fiberglass Shower? Jan 16, 2015
Plumbing Forum, Professional & DIY Advice Maax Maui tub Feb 3, 2009
Plumbing Forum, Professional & DIY Advice How to fix condensate line draining to vent stack? 21 minutes ago
Plumbing Forum, Professional & DIY Advice how to properly do drain for the washer Today at 2:28 PM
Plumbing Forum, Professional & DIY Advice Tub trip lever drain won't plug shower Tuesday at 5:58 PM
