Lukewarm hot water in house after valve change in shower under construction
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by caliskier, Dec 29, 2010.
  1. caliskier
    caliskier New Member
    Sorry if this is a repost, it looks like the first post did not take...
    We installed a rough-in valve in our master bathroom, we have only put the test cover on to the valve as the construction is still ongoing. Since the installation, the hot water in the other bathroom only gets up to lukewarm, not hot. Nothing else has changed. I think air got in the lines because I had a couple of faucets open when I was replacing my valve, I don't know if that is a big deal.
  2. hj
    26,537
    Whoever installed the rough in body did NOT install the bypass plug to prevent that from happening. If the plug has been lost or dislodged, you can install the valve cartridge to correct the problem.
Similar Threads: Lukewarm water
Plumbing Forum, Professional & DIY Advice, Tips & Lukewarm water, not a heater issue...? Apr 3, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Lukewarm water in Master shower/lavatory Jan 17, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Lukewarm water all faucets Sep 13, 2009
Plumbing Forum, Professional & DIY Advice, Tips & Lukewarm water in all sinks and showers Dec 11, 2008
Plumbing Forum, Professional & DIY Advice, Tips & Help! Only lukewarm water May 22, 2007
