Low *Tub Spout* Flow with All New Plumbing
Borisj
Texas
I just built a guest house myself. Everything is new, including pipes. With no cartridge installed, and the stops open far as they go (~½” of threads showing), I get ~8 GPM flow out of the Delta rough-in valve body (R10000-UNWS).
I’ve tried 3 cartridges (w/3/4" x 12" L brass nipple from valve body to spout drop-ear) and all badly reduce flow from the tub spout (i.e. showerhead flow restrictors are irrelevant here). #1 (RP46463) reduces it to 1.9 GPM. #2 (same model) reduces it to 2.3 GPM. #3 (RP47201, higher flow) reduces it to ~3.4 GPM. I’ve never installed a Delta cartridge before, but it seems straightforward, what could I be missing?
GrumpyPlumber
Licensed Grump
Licensed Grump
Showers are supposed to be 2.5 gpm max by fed guideline (water saving), tubs a little more, running water through the open chassis of a shower valve is not what you can expect from the actual valve.
I’ve tried 3 cartridges and all badly reduce flow from the tub spout (i.e. showerhead flow restrictors are irrelevant here). #1 (RP46463) reduces it to 1.9 GPM. #2 (same model) reduces it to 2.3 GPM. #3 (RP47201, higher flow) reduces it to ~3.4 GPM. I’ve never installed a Delta cartridge before, but it seems straightforward, what could I be missing?
How many gpm for all-cold and for medium? I am wondering if there is some temperature thing, or maybe a path size thing.
Borisj
Texas
I know, letting water run through the open chassis, was an experiment to prove that the plumbing before the chassis/rough-in is not the problem. When I put the cartridge in, I do not get anywhere near the stated flow rate for the *tub*... which is not affected by the 2.5 GPM restriction. Either way, the shower doesn't hit its rating either (tops out at 1.3 GPM).
All my measurements are all-cold. Path size can't be the problem - the shower/tub is the first thing in line, and the fixtures later in the line have their expected/rated max flow (e.g. the washer shutoff set).
If the path thru the valve inputs limits you, then medium may flow more GPM thru the tub spout.
I did not intend to imply that I had knowledge of those cartridges, but I only proposed an experiment.
GrumpyPlumber
Licensed Grump
Licensed Grump
You may have gotten flux or sediment in the cartridge, soak in vinegar, let it sit, then shake it the vinegar.
If this happens to be a Jacuzzi valve, that's a known issue.
Borisj
Texas
The cartridge is totally clean and brand new. And it wasn't installed when I piped. Personally I would never solder near a cartridge. In this case, the tub spout outlet of the mixing valve goes 1/2" MPT (on cartridge) -> 1/2" to 3/4" FPT brass coupler -> 3/4" FPT brass nipple to tub spout drop ear. It's a Delta valve.
