Loosing Pressure
Discussion in 'Irrigation / Sprinkler Forum' started by johnjh2o1, Apr 27, 2011.
  1. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    What would cause a two zone index valve system to loose pressure in one Zone? I don't believe there is a leak in the zone because if I open the hose bib between the pump and the index valve the zone doesn't loose pressure. Also if I remove the disk in the index valve so both zones run at the same time the pump doesn't loose pressure. Could it be a leak in the suction line?
    John
Similar Threads: Loosing Pressure
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
