Light Switch - Not sure what to do
Discussion in 'Electrical Forum discussion & Blog' started by coopns, Dec 20, 2009.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    I was changing the old light switch to a new white one. The old swtich has two black and a red wire. The new light switch has just two screws brass right?
    I included some pic's of the old, new and inside the box.
    And...does it matter where I connect the white and black if only two brass screws are on the new switch?
    Please advise.
    Thanks.
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    3 screws generally means a 3-way switch. Is there another switch, somewhere, that also controls that light?
  4. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    There is. So I would need a 3 way switch?
    And, as I asked earlier, does it matter where the black, red go on the switch...black to brass, white to ?
    Thanks.
  5. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    Its hard to tell by your pictures, however on a three-way switch there is a common screw. It looks as best as i can tell the black goes on the common scerw. That is from you pics.
  6. codeone
    Sep 5, 2008
    North Carolina
    This looks like what you have as best as I can tell
  7. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    When you get your new 3 way switch, move the wire from the black colored screw to the odd colored screw on the new switch. Now move the other two wires to the other screws on the new switch. These do not matter, only the odd colored screw matters.
  8. hj
    switch
    IF your switch does not have the words "on" and "off" on it then you have a 3way switch and it DEFINITELY matter where you connect the wires to it. The two from the bright screws have to go to the new bright screws but can go to either one of the two. The dark, "common", screw is either the hot wire to the switches, or the load wire to the light, regardless of what the wire color is.
Similar Threads: Light Switch
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Light switch with pilot Nov 25, 2016
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
