Lennox, Tran Vs. Ruud Ac
Discussion in 'HVAC Heating & Cooling' started by River Rat, Aug 16, 2007.
  1. River Rat
    River Rat New Member
    Aug 13, 2007
    I would to know how Lennox and Tran compare with RUUD AC?
    PRO and CON about all three AC in the 13 SEER.
    Which one uses the most kHw and the one that uses the less kHw? Yes I know we are talking about the same seer.
  2. jadnashua
    If the sizes are identical and the SEER is the same, their energy use should be nearly identical. The differences might come in with the air handler and the choice of fan speeds and the timing of how long it runs the fan, which is a function of the thermostat and air handler control circuits.
    Compare the warranties and features.
  4. River Rat
    Aug 13, 2007
    Yes that would be one of the BIGGEST things to check WARRANTIES and FEATURES of the three, you maybe surprizzed at them.
    Also how loud they run.
Similar Threads: Lennox Tran
HVAC Heating & Cooling Lennox MS7C mini split? any first hand knowledge? Mar 22, 2016
HVAC Heating & Cooling Lennox to Honeywell Thermostat Jan 9, 2015
HVAC Heating & Cooling Lennox Heat Exchanger AC unit keeps blowing the capacitor. Aug 20, 2012
HVAC Heating & Cooling Lennox Furnace not kicking on unless thermostat is turned off then on Dec 26, 2010
HVAC Heating & Cooling Furance fan speed on Lennox HELP Dec 10, 2010
