leeching fields and cesspools in a high water table
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by juan, Nov 18, 2006.
  1. juan
    juan New Member
    Nov 18, 2006
    i own a small ranch 100 yards from the ocean, and although it's beautiful, it has a very high water table and my drain system has become an issue. i cant install cesspools taller than 2 feet because as soon as i go down 3 feet i hit water. i have installed four 2 feet deep, 6 feet round rings. the problem is that when i run laundry or on a high tide day, the water runs out of places to go. i've been considering adding a leeching field, but i dont know if that will help, or pull ground water into the ceptic system.
    is there a minimum height that the leeching field must be? ideally a foot below the ground would keep it away from ground water, but i dont know if that will allow the smell to come up(or create a muddy mess for that matter).
    i've tried draining the pools, but to no avail as the next day they are filled with ground water again. any advise as to how i can cure theis problem?
    thanks in advance.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If you have land away from the ocean, you can pump the deptic tank output to a leach field that is farther above the water table and away from the ocean.
    In the US it has become common to put leach fields in a mound that is constructed above the water table.
Similar Threads: leeching fields
Plumbing Forum, Professional & DIY Advice Need septic tank/leeching pipe advice Feb 8, 2008
Plumbing Forum, Professional & DIY Advice Switching Drain Fields Question Soggy new one vs reusing old one Jan 28, 2010
