Leaky Shower Arm
Discussion in 'Shower & Bathtub Forum & Blog' started by Chrispy, Sep 5, 2009.
  1. Chrispy
    Chrispy New Member
    Sep 5, 2009
    Circle Pines, MN
    The joint between the shower arm and the plumbing in the wall has a small leak coming from it. I've got it hand tight with teflon tape on the threads and lined up at the correct angle. I tried turning one more revolution on it, but could only get it 1/4 turn farther. The leak did slow down after the 1/4 turn. Could I get away with that extra 3/4 of a turn with a wrench without hurting anything? Thanks for the help.
  2. Ian Gills
    Jul 24, 2007
    USA
    I have never done this so keep that in mind.
    But I would try re-doing the Teflon tape. Do it nice and tight with three or so turns.
    It is possible to wrap Teflon tape incorrectly so it starts to shred when you tighten it down and it should not be doing that.
    I also put some pipe dope over Teflon as well. Seems to help.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    How many wraps of teflon do you have on it?
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Replace the shower arm. It sounds like the old arm failed. ( not an uncommon problem) When trying to remove the old arm it may break at the joint in the wall. In that case you will need a easy out to remove the remaining part of the arm before installing the new one.
    John
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Personaly when I install shower arms I don't use any wrenches...just my hands.
  7. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Be very wary of the replacement shower arms on the shelves. I couldn't get one to seal on either end last week with teflon tape despite trying several different ways. The threads were crap! None of them were cut properly, and not a single one on the shelves was any better (checked several stores). The threads were not cut deep enough and were essentially square. Since I didn't have a thread cutter that size I took it back. I put the old one back on easily and it sealed perfectly on the first try, both ends.
Similar Threads: Leaky Shower
Shower & Bathtub Forum & Blog Leaky shower head Oct 2, 2016
Shower & Bathtub Forum & Blog Leaky shower... Is this fix correct? Jul 29, 2014
Shower & Bathtub Forum & Blog Need help replacing leaky shower Jan 15, 2013
Shower & Bathtub Forum & Blog Leaky shower faucet, drain that doesn't shut off and improvement in shower control Oct 27, 2011
Shower & Bathtub Forum & Blog Leaky Tub Faucet + Low Shower Head Hot Water Pressure May 27, 2011
