Leaking water heater flex fitting, 2 DIY questions
ufgatorpolo
FL
This is the line leading from a water heater to the thermal overflow tank. We have a leak at this point, somewhere inside the connection. I'm wondering if the best plan is to loosen this connection, replace the gasket/ rubber washer that I'm assuming is inside there, teflon tape, and tighten.
Otherwise (and also) I'm trying to figure out the black- band connections used here, which are not compression fittings (turn a screw) and resemble a zip ties but with no obvious ratchet or anything else. It's just a band around the fitting.
Thanks in advance, and I'm now at the mercy of the internet.
Those are PEX crimp connections.
It looks to me as if the leak is on the bottom nut on the copper connector. If so, I would try giving that leaking brass nut another 1/8 turn. If that doesn't do it, maybe apply a little pipe dope and tighten again. There should be no tape.
ufgatorpolo
FL
Pipe dope and tightened last night. Looks good this morning. Appreciate the time, and I learned something with "PEX crimp".
