Leaking Waste Drain Stack
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by Duke76, Sep 17, 2009.
  1. Duke76
    Duke76 New Member
    34
    I've been trying to locate a leak that originates in the attic when it rains. I finally found the problem. The waste drain stack comes out of an interior wall, runs horizontally for about 20 feet, then turns vertical again up through the roof. The problem is that the horizontal run is slightly sloped away from the interior wall. Rain enters the vertical and has no where to go. The pipe is leaking from the joint of the 90 degree ewhere it connects to the vertical pipe.
    Can I simply raise the horizontal pipe with a piece of wood so that it drains back to the drain system ?
    I assume it would be better to replace the leaking elbow but there is no flooring, lots of insulation, and tight work space so I would rather not get that involved.
    The vertical pipe seems to be loose at the top where it goes through the roof. From outside the house the pipe is metal so I assume there is some sort of a fitting. Is it supposed to be loose ?
    Thank you for your help.
  2. Ian Gills
    2,780
    USA
    This sounds horrible. I doubt the elbow is leaking but that the flashing for the stack has deteriorated (or is missing) from the roof. Are you sure rain is not dripping down the outside of the pipe?
  3. Duke76
    Duke76 New Member
    34
    I just checked it again. There is no sign of leaking at the roof. No water stains. The vertical pipe is not wet. It only leaks when it rains really, really hard. That makes it really hard to track down.
    Normally there is only air in this pipe so that's why I thought I could change the slope slightly.
  4. hj
    26,485
    leak
    If the fitting is leaking but you change the slope, you will eliminate the symptom, but the pipe can still leak.
Similar Threads: Leaking Waste
Plumbing Forum, Professional & DIY Advice, Tips & Waste Pipe Leaking Jun 18, 2011
Plumbing Forum, Professional & DIY Advice, Tips & Badly Rusted/Leaking Main Waste Pipe Oct 20, 2008
Plumbing Forum, Professional & DIY Advice, Tips & leaking waste outlet Dec 19, 2004
Plumbing Forum, Professional & DIY Advice, Tips & Kitchen P-trap leaking. What am I missing? Aug 5, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Pex swivel adapter leaking like crazy! Jul 1, 2014
