Leaking swivel joint on chrome trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by King3244, Jun 20, 2006.
  1. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    I have just installed a new lav. with an exposed chome trap. The swivel joint is leaking very slowly and I have tightened it as much as I dare.
    Can I use some plumbers putty on this joint or any other suggestions?
    King
  2. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    First, make sure the pipes are aligned and that the gasket is in place. Check to make sure the gasket is not deformed or defective. Next, try not tightening it quite so tight. Perhaps the gasket was squeezed out of the joint. You can try a little pipe dope or dish detergent to lubricate the threads.
  4. hj
    leak
    Without seeing it, we cannot tell a whole lot about the problem or the solution, but when you assembled the trap did you put the rubber gasket between the two trap sections or under the slip nut?
  5. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    Aaaaaahhhh...........no gasket supplied! Just to make certain, this is the swivel joint not the slip joint.
  6. hj
    joint
    The swivel joint will also have a gasket, unless it is a ground joint union, in which case you should use some pipe joint compound on the surfaces to minimize friction.
  7. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    Thanks HJ...........the only gasket that came with this (in a sealed plastic bag) was for the slip joint gasket. I have dealt with plastic (abs) traps before and they all have no gaskets at the swivel but this is my first time with a chrome trap.........be gentel it is my first time :p. I will give the pipe joint compound a try.
  8. hj
    trap
    The question is whether the chrome trap has a tapered connection at the swivel joint like a plastic trap does. Very few brass traps have that type of swivel connection.
  9. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    Okay I took this bad boy apart today and it does indeed have a bell on it.
    I put some teflon tape on the bell and on the threads and that has done the trick. :D
Similar Threads: Leaking swivel
Plumbing Forum, Professional & DIY Advice Pex swivel adapter leaking like crazy! Jul 1, 2014
Plumbing Forum, Professional & DIY Advice Swivel faucet leaking after reinstall...... Mar 30, 2009
Plumbing Forum, Professional & DIY Advice Kraus faucet leaking Today at 1:43 AM
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
