Leaking Refrigerant, My problem or dealers?
Discussion in 'HVAC Heating & Cooling' started by PlumbBobSquarePants, Sep 8, 2007.
  1. PlumbBobSquarePants
    PlumbBobSquarePants New Member
    Dec 10, 2006
    The leak appears to be in the line between the outside unit and the inside unit. When the dealer installed the new A/C unit they did not replace the line from the outside unit to the inside unit, they reused the old one.
    Should they have replaced the line? Is it standard to reuse the old one?
    Can the old R-22 line handle the higher pressure 410A refrigerant?
    My old system never leaked.
  2. jadnashua
    Don't know, somebody will. What I do know is that some of the refrigerants can be used with coils that are contaminated with older stuff and some can't. Normally, the coil is a little different and your efficiency may not be up to where you expect it if the compressor, refrigerant, and coil are matched up.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Depends on what the contract read and where the leak is. If the leak is where the new unit was braised to the old line then they pay. If the leak is just somewhere in the middle and the contract said they would use the old line you pay.
  5. PlumbBobSquarePants
    Dec 10, 2006
    So there is generally no harm in reusing the old line?
  6. hj
    The line is "neutral" in that it does not really care what is inside it, the difference is the units at either end.
Similar Threads: Leaking Refrigerant
HVAC Heating & Cooling Oil boiler leaking fumes/smoke? Owner insists on NOT calling professional Pictures inside. Dec 15, 2015
HVAC Heating & Cooling Help! Exchanger on Pool Heat Pump Leaking! Mar 8, 2014
HVAC Heating & Cooling Beckett Oil Bruner Leaking Oil From The Bottom Of The Plastic Case ??? Mar 1, 2011
HVAC Heating & Cooling PVC Pipe Connected To Metal Drip Pan is Leaking Aug 15, 2010
HVAC Heating & Cooling Leaking Weil MCClane Boiler Feb 7, 2009
