KCmark
Yesterday I discovered that one of our outdoor faucets is now leaking through the anti siphon (vacuum breaker assembly) and spraying out under the plastic cap when the faucet is turned on. I assume that this is repairable by replacing the seals in the vacuum breaker assembly or, if necessary, the entire assembly. The sillcock is made by Woodford.
I haven't shut off the water and disassembled anything yet, but am wondering if this type of leak is usually due to a failed seal/washer or if it’s usually a failed plunger, where the entire assembly needs to be replaced. Just wondering if I can try to replace the seals first or if I should just go ahead and try to find a new vaccum breaker assembly (assuming I can find one compatible with the Woodford sillcock.) Anyone know if replacements are available for Woodford sillcocks? If not, any recommendations when purchasing a replacement sillcock?
Thanks in advance,
Mark
Thanks in advance,
Mark
