Leak in solar panel
Discussion in 'Solar and Geothermal Water Heating Forum' started by wanderl1, Jun 14, 2009.
  1. wanderl1
    wanderl1 New Member
    Jun 12, 2009
    I have solar panels to heat my pool. They have pinhole leaks. Last year I used aquarium glue to stop the leaks which have re-occurred. What can I use to plug these leaks? The panels appear to be plastic or a similar substance.
    Larry
  2. protech
    protech Master plumber
    Feb 16, 2009
    Master plumber
    Central Fl
    Well, first you need to find out WHY the leaks happened in the first place.
    As far as plugging the leaks, you need something like this. They usually don't last long though.
  4. dextercath96@gmail.com
    dextercath96@gmail.com New Member
    Dec 31, 2009
    philippines
    Solar Power Generator
    I suggest to change your solar panel. Because it is already damage. Can you help me in building up a solar power generator? Your comments and suggestions are much appreciated.Thank you. http://www.sunpowerport.com
  5. rogerd
    rogerd New Member
    Feb 21, 2011
    Spammer
    India
    These leaks keep recurring. Same problem with mine too. I have already tried fixing it twice, but the leak reappeared at another spot in the tubing this time. any one why this happens? My system is quite old - about 15 years old. Do I need to replace it?
  6. cssolar
    cssolar New Member
    Dec 20, 2010
    agost alicante SPAIN
    water leak
    If the system is indirect, maybe you could add some car rad weld into ( the non used water part of the system )
    Regards Tony cssolar
  7. hj
    Solar pool heaters are NOT indirect, and are usually made of ABS plastic. If it has small individual tubes, you can cut them at the leaks and use John Guest "push on" 3/8" couplings to splice it back together. Otherwise, and especially since it seems to have multiple leaks, either check to see if your panel has a "lifetime" warranty or replace it/them because they are "worn out".
  8. protech
    Feb 16, 2009
    Master plumber
    Central Fl
    Actually, it not ABS it's usually polypropylene. I'm not aware of a panel on the market that use can repair with a 3/8"ID cts pushfit fitting.
    To the OP: If leaks keep reoccurring, You are probably patching them wrong. Most panel damage is either from freezing or over pressure due to a closed system.
    Panels can just start leaking for no reason other than sun exposure after 20 years.
Similar Threads: Leak solar
Solar and Geothermal Water Heating Forum Leak in Solar Flat Panels Jun 7, 2009
Solar and Geothermal Water Heating Forum Replacing Solar Storage Tank Jan 10, 2017
Solar and Geothermal Water Heating Forum How to disable my batch solar hot water heater temporarily Dec 8, 2016
Solar and Geothermal Water Heating Forum Plumbing Water Heater Into Solar Loop Sep 24, 2016
Solar and Geothermal Water Heating Forum Solar water heating optimization Jun 5, 2016
