lead flared pipe/installing a flange
Discussion in 'Toilet Forum discussions' started by BobMin, Apr 19, 2007.
  1. BobMin
    BobMin New Member
    Apr 19, 2007
    teacher
    New York
    I have a lead closet bend, that goes into a cast iron soil stack on the second floor of my house. I know the proper thing is to replace all the lead from the flange to the soil stack. However the lead is in excellent shape, I don't have the money to have someone replace that plus the galvanized waste lines that jut into it from the sink and the tub, and if I do it myself I'm not qualified for other problems that might arise while doing the job.
    I'm going to be installing a 1/4" subfloor and then sheet vinyl on top of that, which will bring the floor up from the flared lead closet bend.
    What is the best way for a diyer to install a flange on the lead closet bend and also make it so that the flange is the proper height ( as if it where seated ontop of the subfloor)
    Bob
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    You already removed the old flange?
  4. BobMin
    BobMin New Member
    Apr 19, 2007
    teacher
    New York
    flange
    There was not a flange under the toilet, only a wax ring with a horn and the flared lead pipe
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Yes, some old timers used to peen the lead over onto the floor and use closet screws, not bolts to hold the toilet.
  6. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    There is a flat brass flange still available for lead bends. It is to be put over the lead riser, then fastened to the floor and finally the lead riser is pounded down onto the flange.
Similar Threads: lead flared
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Oatley Twist-N-Set into Lead Bend? Nov 12, 2015
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions Cast Iron / Lead Flange Condo - Repair / Replace Jul 22, 2015
Toilet Forum discussions Brass to Lead Flange Setup Jul 18, 2015
