Lav flow rate handwashing to activate tankless heater?
Discussion in 'Tankless Water Heater Forum' started by AcidWater, Nov 25, 2008.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    I'm looking at a mini-tankless water heater that requires a flow rate of 0.53 GPM to turn on the heating element.
    How much flow from a lav faucet is 0.53 GPM ?? Is that a fully opened tap, half open, or what?
    I'm concerned that we usually don't turn on the tap enough to reach that flow rate; in which case a mini-tank would be what we want instead of the tankless.
    And I've seen a few brand names mentioned here; what are some that I can investigate for their tank type (metal vs plastic) & other qualities to choose from ?
    I also have to decide based on the amps required; I'm going to have to install a new electric cable from the fuse box and i'd like to run the smallest gauge i can get away with.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Forget the whole idea, those heater are all junk.
  4. hj
    heater
    The heaters you are asking about are completely useless. The ONLY way you get warm water from them is when you use their restrictive aerator which only flows a few small jets of water. Replace the aerator to get adequate flow and the water flows through too quickly to even get warm. AND they need 30 amps or more, depending on their wattage.
Similar Threads: flow rate
Tankless Water Heater Forum Rheem problem with water flow switch Oct 11, 2016
Tankless Water Heater Forum Ok to disable flow sensor? Jan 21, 2016
Tankless Water Heater Forum Water flowing through tankless heater at beginning and end of cold water draws Nov 20, 2014
Tankless Water Heater Forum Tankless gas water heater overflow pipe? Apr 30, 2014
Tankless Water Heater Forum Can Someone Explain Navien's "ComfortFlow" Technology? Apr 23, 2014
