Large diameter shower arm flange/escutcheon
Discussion in 'Shower & Bathtub Forum & Blog' started by jdkimes, Nov 12, 2004.
  1. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    I need a large outer diameter escutcheon (the flange that goes over the shower arm) to cover a hole that's bigger than the escutcheon provided.
    The one provided is about 2 1/2" diameter. I need one about twice that big (it's a long story but it's my own fault). :rolleyes:
    Are there any made that big? If so where do I buy one?
    Is there something that I could put together that would work? I was think of maybe getting one that would normally be used for a shower valve and somehow use that.
    The shower is white fiberglass so something white that I could glue/caulk on then put the original on would also work.
    Any ideas and sources for purchase greatly appreciated.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    I don't know how large a city you live in. You might have to go to a larger dity and locate a plastic supply house. They can provide a piece of white acrylic of the proper diameter, and a hole for the arm. You could epoxy this to the fibreglass, then trim the arm with a standard escutcheon.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Fiberglass Repair
    Drilled wrong huh? It might be easier to have a fiberglass repair company fix the hole. They're usually not that expensive. Glueing a patch of vinyl onto the unit might look like a patch. How come you use a cartoon character avatar on john bridges site but beer here?
  5. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    I haven't been able to figure out how to get my own avatar's on here.
    I live in Denver so should be able to get the acrylic piece.
    I did drill wrong but it had to do withe fiberglass shower insert not being that plumb or square. Next time I'm going to do a tile shower.
  6. LonnythePlumber
    Sep 6, 2004
    Wichita, Kansas
    Hey Terry
    Can you give jd the avatar he has on john bridges site or tell him how? And jd I haven't been mounting shower arms in shower units for years. They're usually too low. You can also install a white sink hole cover like we use to blank off a hole in a kitchen sink.
  7. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Thanks for the avatar, now I'm Homer here too. We share the same hairline although I'm only forty.
    I did get a little plastic shop (lots of them around Denver) to cut me a nice white acrylic hole cover (I don't know what else to call it) and it doesn't look too bad with the supplied escutcheon. Good deal at $6.75.
    I did mount the shower arm higher than most at about 75" from the floor of the shower, I don't like bending down to wash the skin on my head (get it: no hair). The shower I bought was the "tall" version, otherwise I would have had the arm coming out of the wall to avoid the low shower head.
    Like I've said not sure I'd do the fiberglass insert again, didn't save much time, effort, or money. It looks fine but tile would be more value on resale too.
Similar Threads: Large diameter
Shower & Bathtub Forum & Blog large diameter (7 inch ) escutcheon/shower faucet chrome plate Apr 8, 2005
Shower & Bathtub Forum & Blog Help with Large Master Shower plumbing Mar 17, 2015
Shower & Bathtub Forum & Blog Large format shower tile Feb 23, 2015
Shower & Bathtub Forum & Blog Failure of a large mud shower pan. Oct 19, 2014
Shower & Bathtub Forum & Blog Connecting smaller bathroom sink drain to a large P-trap? May 4, 2013
