Kohler 3397 flapper
Discussion in 'Toilet Forum discussions' started by swimfan, May 26, 2007.
  1. swimfan
    swimfan New Member
    May 26, 2007
    I have a problem with the flapper on my Kohler 3397 staying down. I have replaced the flapper three times in the last 2 years. (So, it isn't the age of the flapper itself)
    It seems to work for awhile. But, then it just stops on it's own with no explanation. I have replaced with the correct flapper, and now have tried two generic versions as well.
    Any ideas of why this is happening? and any solutions?
  2. jadnashua
    Do you use anything inside the tank like one of the cleaning tablets, or any other chemicals? If so, stop!
  4. hj
    flapper
    I never use the Kohler OEM flapper, always the Lavelle Korky version and never have those problems.
  5. swimfan
    swimfan New Member
    May 26, 2007
    Yes, I have tried the Korky flapper. I have also taken the styrofoam piece out of the flapper thinking that was part of the problem.
    It's almost as if there is not proper suction to hold it in place. But I can't determine why that would be. There is nothing that I can find in the path from the tank to the bowl.
  6. hj
    flapper
    Without the styrofoam it will not stay open the proper amount of time. Suction does not keep it closed. The weight of the water on the top of it, pushes it closed. If it leaks there is some other problem, possibly a cracked flush valve, or a defect in the seal area.
Similar Threads: Kohler 3397
Toilet Forum discussions Kohler K3397EB toilet replacement or repair Dec 3, 2008
Toilet Forum discussions kohler 3397EB Rim Feed continues to run Nov 23, 2008
Toilet Forum discussions Kohler Flush Valve Giveaway Sunday at 5:40 PM
Toilet Forum discussions Kohler Leaks & Seeps-Newest 1.28 GPF DISASTER! Friday at 4:50 AM
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Feb 20, 2017
