Knocking in boiler pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Tom H, Dec 14, 2004.
  1. Tom H
    Tom H New Member
    Dec 14, 2004
    I have hot water heat in my home, with a new boiler but quite old pipes. At night we hear a tapping or small knocking noise in some of the pipes. The pipes in question are not the copper ones that run through the floor board radiators, but larger cast iron pipes complete the circuit to the boiler. I know it is not the banging that comes from too much air in the system, because we've had that problem. This tapping is repetitive, there's almost a beat to it at times. From reading other posts I'm now thinking this may be from the expansion of pipes in areas that are too tight. My question is: Is this dangerous or troublesome for the system - or just a nuisance? Is it common? The pipes are in question are in an outer wall and would require some serious wall demolition to get to.
    Thanks.
Similar Threads: Knocking boiler
Plumbing Forum, Professional & DIY Advice Tapping & Knocking noise coming from apartment walls Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Banging/Knocking sound when tenants flush. Water Hammer Arrestors have been installed. HELP Please! Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Knocking pipe and water "spitting" in highest shower in house Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out knocking pipes... Oct 31, 2016
Plumbing Forum, Professional & DIY Advice Knocking sound when hot water is turned on Jul 10, 2016
