Kitchen-washer cast iron drain is corroded
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pachi, May 2, 2010.
  1. pachi
    pachi Reporter
    May 2, 2010
    california
    The 2" inch cast iron drain is corroded. It runs almost on 1/3 of the inside of the kitchen. The floor is slab. To re-install the drain in the same location would required to brake the kitchen floor brake the counter top, etc. I am considering re-routing it through the garage along the base of the walls. But the garage is not slope it is flat, would it be OK, and then be slopped the portion going outside the garage into the main sewer line? I am thinking of using ABS pipe to rebuild the drain path for the kitchen and the laundry in the garage. I would need to make three 90 degree turns on the entire path. I am in North California.
    Thank you in advance.
    Fabian
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    You need a minimum of 1/4" drop throughout the entire run. ABS exposed in the garage would not meet plumbing/fire code in CA. Three 90s is too many without clean-outs, meeting code would depend on exactly how it was done.
  4. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    If you can not run the pipe with 1/4"/ft slope then you need a pump. Can you run the pipe outside and put the pipe in a trench to run it to the sewer line?
  5. hj
    If you will not, or cannot, do it correctly call a professional who can and will do it.
Similar Threads: Kitchen-washer cast
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Plumbing Podcast Interview Feb 4, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
